H
Henrywatson
First post for me
Just came across the hardest 500x500 10mm porcelain tiles I've ever had the pleasure of working with. My little wet saw is well out of its depth, using the makita leaves sloppy cuts and the rubi 60+ wont touch them, obviously.
Need to invest in a bench saw I think. Budget is tight and so either the Rubi DU200L - Rubi DU-200-L-BL Electric Wet Cutter 230v + Table or the Virtex 900 - Vitrex Versatile Power Pro 900 200mm Diamond Blade Wet Bridge Radial Tile Saw 900w 240v : Tooled-Up.com would probably suit me for the time being.
I'm drawn to the Rubi because of reputation, build quality and guarantee but the price of the Virtex is tempting however it looks a little on the flimsy side and does weigh 45kg.
Any thoughts and or alternative recommendations would be appreciated.
Cheers
Cheers
