Discuss Safe isolation of rotary isolator when no incoming voltage present. Electrical Advice in the Electrical Advice area at TilersForums.com.
Safe isolation of rotary isolator when no incoming voltage present. Discussion ThreadSafe isolation of rotary isolator when no incoming voltage present. Electrical Advice
Hi all, trying to work out the best way for proving safe isolation of a motor.
Motor is fed from a contactor inside control panel, it then passes through a local isolator and then to the motor, the isolator has auxillary contacts so that when it is in the off position the contactor will not pull in and supply power.
How can i prove that no voltage will flow through the isolator that is locked off when there is none incoming into it?
Safe isolation of rotary isolator when no incoming voltage present. for the original thread on Electricians Forums
Reply to Safe isolation of rotary isolator when no incoming voltage present. Electrical Advice in the Electrical Advice area at TilersForums.com
TF Group Please Join
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
