Discuss Schluter Ditra in the UK Tiling Forum area at TilersForums.com.
But what I didn’t appreciate was that any shock to the floor particularly as you can image in a kitchen with all manner of things being dropped onto it will just crack the tiles because of the additional movement that the matting allows.
I used this stuff to prevent hair line cracks in the screedbeing transferred to the tiles as I had wet UFH installed. I now have varioustiles with cracks through them so I think I’d have probably been better off notusing it at all as I did in my conservatory with the same screed, UFH, tiles& adhesive but no cracked tiles and this is still a heavily used area asthe kids us it as a play room.
This is one of the best products of its type available, I'm surprised you've had issues. Did you ensure to fill all the cups in the matting before fixing the tiles? Also did you fix the tiles using a solid bed trowel and backskim the porcelain tiles?
I did indeed, I've done my share of tiling, what I am saying is that this product is unsuitable for the type of floor that is subject to point loading such as a kitchen, I've never had issues before and would look for an alternative if the situation arises again.
d) Load distribution (load impact)
The bottom of the square cavities in Schlüter-DITRA, which are filled with thin-bed adhesive, directly transfer the load impact on the tile covering to the substrate. As a consequence, tile coverings installed on top of Schlüter-DITRA are highly load resistant. If high traffic loads are expected (e.g. in industrial locations), the tiles selected for the installation must be of the corresponding thickness and pressure stability. The requirements of the mandatory guideline "Ceramic Floor Coverings With High Impact Resistance," published by the German Construction Industry Association (ZDB) must be followed. In areas with high impact loads, the tiles must be fully embedded in the thin-bed adhesive. The contact surface of Schlüter-DITRA amounts to approximately 50% of the total surface. This can reduce the load bearing capacity in case of point loads. For high point loads, select a tile thickness that is capable of distributing the loads. Ceramic tile coverings should not be exposed to the direct impact of hard objects. The tile dimensions should be at least 50 mm x 50 mm.
Utter tosh and really really disagree.. Schluter ditra is used in car showrooms and even airports and shopping malls... if you have cracked tiles then that is deffo fixer error..
Simples..
Reply to Schluter Ditra in the UK Tiling Forum area at TilersForums.com
