Discuss Screed on celotex??? in the UK Tiling Forum area at TilersForums.com.
Had a builder put a floating floor down and I refused to tile on it and said that I wanted it screeded. The builder rang the plasterer to do the screed and he said can you leave the celotex insulation down and I will screed over that. I'm not happy that this is going to be a secure surface either as the celotex isn't fixed to the substrate. The plasterer said that he's done it loads of times and it will be fine. It sounds to me that he's trying to make it easier for himself by not laying as much screed but I don't know enough about screeding to be sure. Has anyone else heard of this method before? The room is 9m2 and it will be a sand/cement screed. Cheers Ross :thumbsup:
Ajax123
1,213
Lincolnshire
Yes laying the screed direct onto insulation is standard practise for a floating floor.
A standard sand/cement screed would need to be laid at a minimum depth of 65mm for a domestic property. If modified screed is used you can get down to 55mm.
British Standard (8204:1) says minimum 65mm for domestic floating sand:cement screed. The standard does not differentiate between non modified and modified sand cement screeds so that should be treated the same e.g. You would have to use a proprietary material and step outside of the standards to go below this depth. That can clearly be risky.
Andy c
It's standard practice but you should not put screed straight on the normal standard cellotex the shiny foil backed one has cement reacts with the foil and forces it to peel away there is a specific one for putting screed on which has a pink coating ,if using standard cellotex you need a membrane between insulation and screed
Reply to Screed on celotex??? in the UK Tiling Forum area at TilersForums.com
gamer1
6K
Good day everyone, and I hope you are all staying good and healthy. Guys and girls,,I have a...
Sealing Moisture resistant plasterboard Hi I am new here, I have been reading through many of...
10K
Bedfordshire
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
