Discuss Sealant for a Porcelain tile? in the Canada Tile Advice area at TilersForums.com.
Hi people
Quick question; I have just laid a Porcelain tile (mosaic) to a floor for a wetroom. And will be grouting it today. But before I did I thought I would check to see if I should use a sealant first as they are a light coloured "shuttered concrete" effect and a was worried about shower gels etc staining the tile?
Also I assume it best to seal the tile prior to grouting, rather than after????? If it does need it what brands would you recommend?
Lithofin BOB
518
Hampshire
As above, any specific porcelain impregnator should do, if required we have protective impregnator.
As mentioned before , be aware even if you impregnate the tile- grout or residues can still get trapped in the micro pore of a tile- these sealing products line the capillary not fill them, test and seal an unlaid tile, let the product cure for the stated time and them check your grout release- if good on the unlaid ,you should be good to complete the area. Check with supplier to see if they need an impregnator
thanks for the expert reply's.
I have found;Lithofin KF Protective Impregnator Porcelain Sealer @ pureadhesion.co.uk it this what you are recommending?
Unfortunately I had to get on with the grouting today, so no protector used, however can the above be used after grouting as well as pre grout sealant?
Is it really necessary, or more just precaution?
The Porcelain tile im using isnt porous, and has a "satin" finish to it, its just a light colour tile and I used Mapei 112 med grey grout, being a wetroom floor I was concerned about coloured shower gels etc staining.
Lithofin BOB
518
Hampshire
As above , if used after all moisture is released from the grout, this will give added protection( water and oil reppelance) to anything with porosity. Best way for client to maintain these areas is to rinse off the tiles (removing any residues from products) and remove surface water, so it doesn't sit there and evaporate or stain tiles or grout.maintain with the correct product.
Reply to Sealant for a Porcelain tile? in the Canada Tile Advice area at TilersForums.com
Please advise me on a sealer or two. I've had white porcelain tiles with light grey grout laid...
A question about mitering and matching epoxy colour I'll be working with some pinkish matt...
HELP! I'm really hoping someone might be able to give me some advice..... our cleaner just used...
Hi, I‘ve just finished tiling the majority of my garden path. Base is concrete, and tiles are...
I could use some help from everyone! The floor mosaic tile was recently retiled over a tile-redi...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
