Discuss sealing around shower tray - best method or practice? in the Tanking and Wetrooms area at TilersForums.com.
what
I intend to tank plasterboard with mapei mapgum (or similar) and tape the joints as shown in this video below. It also shows the tape being bonded to the tray surface then tiled afterwards. Taking into account the thickness of tile and adhesive (which should obscure the joint) there would be about a loss of about 1cm in the width and also depth of the tray, I'm doubtful if the enclosure would still fit okay as the tray size would be reduced somewhat.
Normally I would expect the wall to be tanked and tiled and then the tray and enclosure fitted and then sealed against the tiles.
I'm aware there is an issue at the interface between the silicon bead
and grout, the grout being semi water permeable despite being described as waterproof, but I'm uncertain how important that is in my situation given that the plasterboard surface underneath will been tanked.
Reply to sealing around shower tray - best method or practice? in the Tanking and Wetrooms area at TilersForums.com
Hi all, probably a pretty common question but I'm going around in circles looking online for a...
I'm hoping someone here can give me some advice! I'm re-tiling my shower after needing to rip...
Wetroom leaked. Former and first course of wall tiles removed. WBP ply on joists (shower tray...
Hi I’m fitting a Nova Frameless 1000 x 800 Sliding Door Shower Enclosure with a low profile...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
