Secondary loop pump + pipe stat Discussion ThreadSecondary loop pump + pipe stat Electrical Advice
Hi Guys
Recently finished a new build house.
Commissioning engineer came in the other day (2nd visit whilst I wasn't there) and mentioned we need to put a pipe stat on the secondary loop pump.
We've only ever wired these as on/ off time controlled.
Apparently it's regs (heating engineer we work with hadn't come across this either before)
Any else aware of this ?
If so I assuming it's to prevent pump running if pipe is not up not temperature ?
Thanks Sy
Secondary loop pump + pipe stat for the original thread on Electricians Forums
Hi Guys
Thanks Sy
