selv pelv felv & testing them Discussion Threadselv pelv felv & testing them Electrical Advice
Hi all hope everyone’s well.
Sorry this a long read but I really want to get my head around this… simplified questions at the bottom of the long read…
I’m struggling to understand it as there’s not many videos explaining it and lack of diagrams in GN3. I’ve been through bs7671 section 414 and read through forums on here and the selv pelv pages on TLC but I’m scratching my head even more lol…
So selv would normally be supplied via a step down transformer which may power downlights for example but do not have a earth on the secondary side so you cannot get a shock if one of the conductors shorts to the metal part… These would be useful in zones 0 providing the transformer is obviously outside of zones and your typical downlights like jcc v50 outside of zones…
Then there is pelv, which does have an earth on the secondary side which can give you a shock,
Q1. What is the purpose of using pelv if you can get a shock?
Q2. Will the Rcd/rcbo operate if there is a fault to earth on the secondary side?
in section 414 it mentions about socket outlets being on a selv pelv system.
Q3. When it mentions socket what would be a a current using equipment on a selv socket?
Q4. Ceiling luminaire couplers are mentioned, where selv should only be 2 pin with no earth contact to separate from earth and from low voltage systems? As pelv is earthed then it would be 3 pin?
Q5. What is an example of felv and where would it be used? From what I read it’s not that common and BT use it?
Testing
GN3 Page 74
Insulation resistance testing between live conductors including other selv and pelv circuits
SELV table 2.12
Q6. so you would disconnect the transformer or before it’s connected, you would put primary lives together and secondary lives together and test between them at 250v DC?
Q7. Then test between the secondary lives together to primary earth to make sure it is actually separated from Earth at 250v DC?
Q8. But...
Read more
selv pelv felv & testing them for the original thread on Electricians Forums
Testing
GN3 Page 74
SELV table 2.12
Q8. But...
Read more
