L
ljmountain
I am brick bonding 250mm (length) x 200mm (height) ceramic tiles. I am trying to figure out how to layout the wall shown in pic below, the larger wall which is where the bath is located (to the left of the pic) has a near perfect pattern (i.e ending in either a full tile or half tile).
If I centre the layout then the 120mm pier to the right of the window will have no cuts and I am concerned this will look like I have given up on the brick pattern. If I wrap the pattern around then I will be playing around with cuts of 80mm and 40mm (within the 120mm pier).
I am leaning towards wrapping the pattern, what do you guys think? Are cuts of 40mm acceptable I see posts on the forum mentioning avoiding slithers and narrow cuts but am not sure what size is counted as a slither\narrow cut.
Thanks in advanced from a DIYer who has been setting out tiles all day (I just want to get the adhesive mixed!!!)
