Guest viewing is limited
Discuss Setting out floor for mutiple rooms in the UK Tiling Forum area at TilersForums.com.
N
Noaksy
Hello everyone, would just like to say that this is a great forum, I dont post on here much but I do lurk in the shadows reading lots from time to time! anyway heres my post, have just been told off a possible job from a neighbour whos been working on an extension for someone, and they are wanting the ground floor of their place all tiled,approx 50m2, Ive not been round to see it myself so im just going on what i have been told, they're wanting lounge, hallway kitchen in a shiny tile, im asuming a polished porc, running though the rooms.
Now, i still consider myself a newbie ,I did a 4 week course 2 years ago down at pts in harlow and have been doing tiling jobs in between my main job as I work shifts one week on one off, I was hoping to swap the shift work for working for myself, but for obvious reasons havnt given up the main job just yet, whislt im happing doing bathrooms and kitchens I have not had this come up before and was wandering on the following :-
1. What would be the best way to set this out ,if I set out the lounge floor, then the chances of the hallway and kitchen all working out fine is zero! so surley you have to separate the room or rooms somehow where you cant get the cuts right?
2. I take it movement joints would have to be used?
3. Slc would have to be used to get the floors level im guessing as I havnt seen it for myself, but would you guys also use a backer board on the floors aswell to get a really flat surface?
All help and tips would be very much welcomed:thumbsup:
david campbell
you willbe best using expansion joint between rooms as the threshold strips can cover this without the need for other unsightly systems in the house,it will also help as the extension will need expansions between old and new floor substrates,will the floor be concrete or t&g chipboard? you willneed to find this out before you decide to either level or use backer boards,as height probably wont be an issue if the entire level of the house is being tiled cost however for the client may well be and using ply may save a few quid and ensure you get the job
F
faithhealer
I find this laser from tradetiler invaluble when doing floors. Doing multiple rooms I use this with chalk lines. (and a staff!)
Laser Square by Laserliner
http://www.**************/acatalog/laser-square200.jpg
Perfect for square layouts.
Projects two highly visible red laser lines, set at 90°. The laser lines project along the floor and a good distance up the wall.
Range 30m. . Accuracy 0.05 degrees
Adjustable feet to level vertical tracking from floor up walls
Power 2 x 1.5v AA Batteries included, duration 48 hours.
Includes cary case with laser glasses and batteries
Size 150 x 150 x 50mm.
Weight 1.1kg.
Y
Yorkshire Tiling Services
If the customer doesn't want a break at the doorways, the best solution is to centre your hall left to right, and then play around with the lengthwise setting out to see which works out best to flow into all rooms.
If the customer does not want a break at doorways and it is necessary depending upon meterage,then the customer should be told politely that this is what is required.
The customer will still take you to court if tiles lift,tent or crack if insufficient movement joints have been added.
Dan
Admin
Staff member
5,083
1,323
Staffordshire, UK
The Legend; Phil Hobson RIP
excuse me that sounds interesting,,,what is a staff/guage stick/pinch rod?
Sorry Russ, just seen this. A staff/ guaging stick or pinch rod are all one and the same thing, depending on where you are from. I call it a staff, simply a piece of timber with tile joints marked on including spacers. Using this you can set out walls or floors very accurately, before you fix a tile:thumbsup:
Reply to Setting out floor for mutiple rooms in the UK Tiling Forum area at TilersForums.com
Hi. I've just used Mapei Ultimate Leveller 1210 to cover a very irregular concrete floor in our...
