Discuss Setting out Floor tiles. in the Best Floor Tiles area at TilersForums.com.
GazSuttonUK
Hi All, my first post.
I have done wall tiling before but I now need to Tile a Porch Floor. We have bought 120 mm 'imoker' Gres Porcellanato.
They are a rustic with uneven(wavy) edges.
Sontex RS2 Tile Adhesive.
Biscem Grout.
How do I set the rows out, I cannot use spacers because of uneven edges.
What space between the tiles?
Adhesive - how thick?
Any help will be much appreciated.
Gaz.
White Room
Set your floor out, as you would normally ie find the centres. Do not worry about the edges of the tiles as they are supposed to be uneven just ensure that when you put a straight edge in the centre of the joint it is running true. The joints will vary from 3mm to 5mm
As above:stupid:
GazSuttonUK
Thanks for all the info, much appreciated.
Photo of one of the Tile's.
oogabooga
Gaz, can't help you with the product side of things, but they look like some seriously wonky tiles - I know they're probably meant to look rustic. I normally use a 10mm trowel on floors, unless I've screeded first, and backbutter porcelain - but with tiles that small I'd opt for a smaller trowel maybe 8mm to prevent excessive slumping.
Don't use spacers - I use the eyechrometer instead. :grin: One technique is to ping some chalklines and use these as your controls. Just put your chalklines say 50mm off the tile edges (so you don't lose them under adhesive) and keep checking as you progress so you don't drift off - just make sure your lines are accurate to begin with. Alternatively, if you have a long enough straight edge and the layout is basic, simply anchor the straightedge and use that as your centreline.
I think it's a good idea to move away from using spacers, not many tiles I run across are accurate enough to use them, and also you'll get your "eyechrometer" up and running.
oogabooga
Try dry laying a few to see what spacing works best, the size variation between tiles and the out-of-squareness will dictate this (maybe 5 to 6 mm?? -they look a bit skew-whiff). Even though they are small tiles I'd go with an 8mm trowel and use a small piece of wood as a beating block - to gently tap the tiles once bedded so as to minimize lippage.
Reply to Setting out Floor tiles. in the Best Floor Tiles area at TilersForums.com
Hello, I am looking for some advice on how to set out my tiles. I think I have a solution but...
Hi all, Will I be setting myself up to fail if I use the Dunlop CF-03 Flexible Fast Set Tile...
Quick question about setting up for tiling a 16m2 space in garden. I know the addage about doing...
Best Floor Tiles
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
