Discuss Shared immersion heater circuit Electrical Advice in the Electrical Advice area at TilersForums.com.
Shared immersion heater circuit Discussion ThreadShared immersion heater circuit Electrical Advice
Hi everyone
Is it permissable to connect 2 immersion heaters to one RCBO and supply cable?
I'm installing a water cylinder (which has 2 immersions) in a new utility room, which used to be a kitchen.
I want to repurpose the old cooker supply cable which is 10mm. If it's legal, I want to feed both immersions vis seperate DP switches, but they will share the same RCBO in the consumer unit.
In short, is there any way I can use this cable to power 2 immersions? Pulling another cable via the same route as the original isn't possible - I'd have to run it along the outside of the house. If I have to I will, but it's not ideal.
Thanks for any advice.
Shared immersion heater circuit for the original thread on Electricians Forums
Reply to Shared immersion heater circuit Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.6%
    Votes: 17 10.5%
    Votes: 11 6.8%
    Votes: 45 27.8%
    Votes: 21 13.0%
    Votes: 38 23.5%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.6%
    Votes: 19 11.7%
    Votes: 17 10.5%
    Votes: 8 4.9%
    Votes: 5 3.1%
