Discuss Shelf on a Kerdi-Board Wall in the Canada Tile Advice area at TilersForums.com.
Mossop
The image shows a sketch showing the location of a bath within a bathroom and an alcove in the room at the end of the bath.
Due to an overhead shower, the stud walls are to be faced in Schluter Kerdi-Board and tiled to the ceiling. I was considering a shelf to be placed at the location indicated within the alcove. This would be over 2 metres above floor.
Would you have any suggestions on doing this?
Would the walls be Kerdi-boarded first, tiled, then a shelf inserted? Or would the shelf somehow be constructed during Kerdi-boarding and before tiling?
What would you construct the shelf from? Kerdi-Board does come in 50mm thickness, which perhaps could be used to construct such a shelf? Would you tile top, bottom and front of the shelf?
Thanks.
Mossop
What tiles are you fixing and what are you hoping to keep on the shelf?
Metro tiles. Perhaps just a store for loo rolls.
If the shelf is over 2m above the floor I would think nothing you want to get to very often..
Perhaps 2m, haven't measured exactly as yet.
Hi,
In the Schlüter-KERDI-BOARD range there are profiles that have been designed to enable shelves, vanities, seats etc to be constructed. These can be seen in the Profiles and accessories section (Profiles and attachment hardware | Schlüter - http://www.kerdi-board.co.uk/profiles-and-attachment-hardware.aspx) on www.kerdi-board.co.uk.
If you are looking to include niche shelves within the walls then may I recommend the Schlüter-KERDI-BOARD-SN (Shower niche | Function | Schlüter - http://www.kerdi-board.co.uk/shower-niche.aspx), these are a range of preformed and pre-sealed niches and can save hours on installation.
As ever if you require further information on the Schlüter-Systems range then feel free to call us on +44 (0) 1530 813396 and our consultant for your area will be happy to advise.
Mossop
Just so I fully understand, the walls on either side of the shelf in my diagram would be boarded in Kerdi-Board, then steel profile externally attached horizontally to these Kerdi-Board walls and a Kerdi-Board shelf inserted.
Then at that point (one shelf has been inserted), walls and shelf would be tiled?
Method sounds correct. Once done would be good to see pictures as you go, and once completed.
Mossop
I saw a film on Youtube of a triangular Kerdi-Board toiletry shelf being installed in a bathroom. The installer used 25mm thick Kerdi-Board, though the shelf looked small.
The triangular bathroom shelf (from my diagram above) would measure approximately 77cm x 50cm x 60cm,
Do you think 25mm thick Kerdi would be okay?
Dumbo
I would get a shelf that size made out of toughened glass and sink it into the tiles to support it .
You'd need to consider the weight of the tiles, adhesive and grout along with what would be placed on the shelf.
Reply to Shelf on a Kerdi-Board Wall in the Canada Tile Advice area at TilersForums.com
Hi all, I am in the middle of renovating my bathroom. First of its kind for me! The walls were...
Hi All Cheers for the advice on here so far my DIY bathroom build is moving well and the end is...
Paramount wall fix for tiling ideas? the plan is (or was) to tile floor to ceiling with 200mm x...
Hello, I'm having problems finding a tiler who knows how to use Kerdi board. I've had a few...
    Votes: 5 4.6%
    Votes: 8 7.3%
    Votes: 6 5.5%
    Votes: 30 27.5%
    Votes: 14 12.8%
    Votes: 28 25.7%
    Votes: 3 2.8%
    Votes: 2 1.8%
    Votes: 19 17.4%
    Votes: 18 16.5%
    Votes: 13 11.9%
    Votes: 5 4.6%
    Votes: 3 2.8%
    Votes: 1 0.9%
