Discuss Shine on tile in the Canada Tile Advice area at TilersForums.com.
russ1
Hi all
Just finished tiling Matt porcelain floor cleaned up but noticed part of the tiles have a shine to them not to sure what it is,have tried brick cleaner on it but not budging now customer has noticed any idea how to remove only thing I think it could be is a blob of Silicon I've rubbed into tile while cleaning up when doing shower screen any help would be appreciated.
Dan
Admin
Staff member
5,094
1,323
Staffordshire, UK
You might have chemically polished it by accident?
What are all the products used in the process so far?
  • adhesive make
  • grout make
  • primer make
  • brick acid make
And anything else.
And where were the tiles from? Are they full bodied porcelain or just a porcelain glaze?
Tony_C
528
Glasgow
Any further info other than matt grey porcelain? do you know the name of the tile or where the customer got them from? is the shine consistent on the same spot on more than one tile or is this just on a couple round one area where a spill could have happened?
I only ask as i asked a similar question and someone here worked where the tiles were supplied from and gave me the answer as it was a common problem with that tile.
Removing transit wax from tiles - https://www.tilersforums.com/threads/removing-transit-wax-from-tiles.88350/
russ1
Thanks for the reply Tony, have info Monday tiled it last week can't remember name of manufacturer I'll take pics Monday before and after hopefully wax or whatever it is removed, just a thought would a small amount of paint stripper work obviously try a test patch on a spare?
[automerge]1562362513[/automerge]
Just read the thread you sent Tony nail polish remover could do it, I just hope I haven't got to replace them.
Tony_C
528
Glasgow
No worries, I'd probably hang fire on throwing any more chemicals at it until you can perhaps contact the manufacturer/supplier once you get to assess it on Monday. I was lucky enough to have Paul here help me fairly sharpish but i never touched the tiles with anything until i had the answer out of fear of damaging the finish. There are other answers in that thread also you could try if you fail to get any information back.
Reply to Shine on tile in the Canada Tile Advice area at TilersForums.com
I have recently laid around 30msq of porcelain floor tiles in our kitchen. The tiles have been...
russ1
Shine on tile
    Votes: 9 6.2%
    Votes: 13 8.9%
    Votes: 11 7.5%
    Votes: 44 30.1%
    Votes: 17 11.6%
    Votes: 34 23.3%
    Votes: 3 2.1%
    Votes: 20 13.7%
    Votes: 18 12.3%
    Votes: 15 10.3%
    Votes: 7 4.8%
    Votes: 3 2.1%
