Discuss Shluter Ditra matting adhesives question in the Canada Tile Advice area at TilersForums.com.
what
I intend to tile the floors of an extension and existing kitchen area with calibrated slate tiles. The existing floor area is a suspended chipboard floor which I need to pull up and re-install as it sloping and does not align with the concrete floor which was laid about 8 months ago. I will take the opportunity to stabilize it further with additional joists, noggins, more sleeper walls and ply . There won’t be any under floor heating.
There will be an interface joint between the concrete and wood floor sealed with polysulphide mastic on the tile joint.
My question concerns the use of ditra matting in both areas. I will be using Ardex AF 200 to bond the ditra to the wooden floor -What is the recommended adhesive to bond the tiles to the matting in this situation?
I understand that it is advisable that tiles should be decoupled even on stable concrete floors using ditra - what are the recommended adhesives for bonding the matting to the concrete and the tiles to the matting.
Apart from the Ardex, I am considering using Dunlop flexible C2F large format & natural stone adhesive or Unibond rapid set grey (as it inexpensive from B&Q trade point) in all the above situations
- will these be compatible?.
or do I need something more flexible for bonding the tiles onto the matting on the suspended wooden floor?
what
Hi There
thanks for your replies . I'm not sure why the geographical source of the Shluter information could have any bearing on this issue as its the same product worldwide.
Anyway, here is some information from the company (Schluter) with regard to modified thinset :
"Can ceramic tile, including porcelain tile, be set on
DITRA with latex-modified thin-set mortar?
ANSWER
We DON’T recommend it. Here’s why:
Latex-modified mortars must air dry for the polymers to coalesce and form a hard
film in order to gain strength. When sandwiched between two impervious materials
such as DITRA and ceramic tile, including porcelain tile, drying takes place very
slowly through the open joints in the tile covering. [According to the TCA Handbook
for Ceramic Tile Installation, this drying period can fluctuate from 14 days to over
60 days, depending on the geographic location, the climatic conditions, and whether
the installation is interior or exterior]. Therefore, extended cure times would be required
before grouting if using modified thin-set mortars between DITRA and ceramic tile,
including porcelain tile. If extended cure times were not observed, the results could be
unpredictable. This is even more important to consider in exterior applications that are
exposed to rain as there is the additional concern of latex leaching."
I have tried to reasearch this matter quite extensively and discovered that there appears to be a lot of conflicting information about, however this is from the horses mouth.
In the light of this I am considering using Mapei Kerabond.
Reply to Shluter Ditra matting adhesives question in the Canada Tile Advice area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
