Discuss Shocking New build tiling. in the UK Tiling Forum area at TilersForums.com.
N
NWB Tiling
This is the 2nd anniversary of moving in to my Wimpey new build. When we first moved in all looked ok. However after recently doing a tiling course the actual qaulity of tiling in our on -suite is actually pretty poor. Ranging from poorly cut tiles to raised uneven field tiles.
Is this common ?
The Silicon has also developed back mould spots. Neighbours are also seeing similar mould issues.
Is this primarly due to cheap product? We were shown to use BAl Microban Silicon i assume this would still be mould free after 2 years ?
Also i am thinking of re-grouting but after reading the forum digging out the old grout seems a tad labourerous and i don't won't to damage the tiles.
I have read about aqua mix to rejuvenate the grout could someone elablorate on how to use it....
Cheers
Nige:8:
GazTech
Is this common ?
Cheers
Nige:8:
Your Silicon won't be Bal microseal if you have black mould in it (aspergillus niger). We do have a product which will save raking out the grout.....Gaz
  • Contains Microban® antibacterial protection: for extra hygiene
  • Inhibits growth of bacteria and black mould
  • Water-resistant
DHTiling
Not to be used in power showers though....:thumbsup:
BAL Microrevive with built-in Microban® antibacterial protection
renews the appearance of existing wall grouts whilst providing an
added level of hygiene protection in kitchens, bathrooms and
food consumption areas. Suitable for interior use only. It is water resistant
but not suitable for use in power showers or where
prolonged or permanently damp/wet conditions exist
L
LM Ceramics
typical new house building we used to tile wimpey homes as well when i was working for a tiling firm the materials are basic everything is rough on new builds
i bet your tiles arent spaced neither probably but jointed its not just your house most major builds are all the same. we were on £9 m2 some tilers i knew could blitz a plot a day its a poor habit house bashing and some of the experience tilers are bringin there house bashing "skills" with them on the domestic market which is not a good sign
GazTech
Ah,
What else would suggest to use in that case ?
Nige
Sorry Nige, if you have a power shower, as Dave rightly points out ( thanks Dave) it isn't suitable. Your only course of action is either rake out and use Microflex or easypoxy grout.
You could try an epoxy paint on solution....again not sure if suited to power showers, consult the manufacturer for details
penno
Get on the phone to Wimpy and get them to take a look. May be 2 years ago but you never know you may get it sorted, if the tiling is that bad then it should have been snagged, it is their fault.
Have a look at some neighbours houses, if there tiling is spot on then you have more of a case to argue as yours isn't of the same standard.
Reply to Shocking New build tiling. in the UK Tiling Forum area at TilersForums.com
Hi there, long time lurker, first time poster. I’ve recently moved in to a new build property...
gamer1
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
Hi. I'm relatively new to tiling, and have begun offering it as a service alongside my existing...
5K
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
