Discuss Should Ditra matting be used for this job in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com.
I have a wet room floor to tile upstairs in a house. The builder is fixing hardibacker board followed by underfloor heating and then self levelling before I lay marble tiles. I told him I think Ditra matting should be used as well, due to marble tiles. Thoughts please and would Ditra matting be laid on board and then heating or heating under Ditra.
Doesn't the ditra heat do the same as the anti fracture mat, is it overkill?
The purpose of the Ditra heat is that it's your
3-4 layers all in one.
Your decoupler and your ufh, and as Schluter don't advocate latexing over it, that element is done away with.
If you tape the joints with Kerdi Keba band and Kerdi Coll, then it's also a waterproof membrane.
One stop shop. :)
Reply to Should Ditra matting be used for this job in the Specialist Tile -Stone, Porcelain, Glass area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Hi Everyone. I'm after some advice with regard large format Tiles with water fed underfloor...
Tiberiu Curelaru
Hi All, I’m ripping out a failed existing tiled floor. Tiles had not been back buttered so...
Tile Buying Popular Threads
Woburn Sands
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.3%
    Votes: 17 11.3%
    Votes: 36 24.0%
    Votes: 21 14.0%
    Votes: 18 12.0%
    Votes: 16 10.7%
