Discuss Should I replace a Redhead Fuse Link with Double Pole Isolator? Electrical Advice in the Electrical Advice area at TilersForums.com.
Should I replace a Redhead Fuse Link with Double Pole Isolator? Discussion ThreadShould I replace a Redhead Fuse Link with Double Pole Isolator? Electrical Advice
Hi Everyone,
I’m currently working on an HMO where the supply cables run from the Ryefield board in the electrical riser to each apartment's utility cupboard.
At present, the armoured cable from the Ryefield board terminates in a Redhead fuse link, and from there, it connects to the consumer unit switch. From what I understand, in the current setup, the Neutral cannot be isolated, as the Redhead fuse link only isolates the Live conductor.
My question is: is this arrangement compliant, or does the Redhead fuse link need to be replaced with a double-pole isolator to ensure both the Live and Neutral conductors can be isolated? I can provide photos of the current installation if needed.
Should I replace a Redhead Fuse Link with Double Pole Isolator? for the original thread on Electricians Forums
Reply to Should I replace a Redhead Fuse Link with Double Pole Isolator? Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
