Discuss should i seal waterproof plasterboard in the UK Tiling Forum area at TilersForums.com.
t2tonesimone
hi am about to start tiling my new bathroom which i have just drywalled with waterproof plasterboard. all screws etc have been covered but the board is bare - as it came. i am just wondering if it needs a mist coat of emulsion first? it wont be very wet walls as the shower is a full enclosure rather than water onto tiles. only place might get a bit wet is round basins. any advice gratefully received :)
StevieBoy
Hi - tiling straight onto bare plasterboard can be done, but if you ever want to change the tiles 5 to 10 years down the line, you will rip the walls to bits.
I would advise getting the walls skimmed, then prime, then tile - at least if you do have a failure on the grout, the plaster is there as a bit of a safeguard.
White Room
If you skim the walls then the tile weights will drop from 32kg m2 on plasterboard to 20kg m2 on skimmed plaster....
Reply to should i seal waterproof plasterboard in the UK Tiling Forum area at TilersForums.com
  • Sticky
Hi I would like to use some indoor tiles outside on the top of my fish pond wall, the tiles I am...
Hiya all, I'm a DIY gal on first bathroom. Wondered if you could check out my plans and let me...
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
