Discuss Shower door in the UK Tiling Forum area at TilersForums.com.
johnfrench10
Hi
I have to fit a shower door in to a recess which is 830 mm wide. Unfortunately every shower door I can find will fit a recess 750-800 mm or 850-900 wide.
Unless you guys have any other suggestions the only think I can think to do is screw a batton on the the wall to take up 30 mm or so and then fit the smaller shower door. The shower recess is moisture plasterboard and I am going to tank it with Mapegum. If I apply the tanking to the wooden batton and tile on to that will that be OK?
Thanks guys
I
Ian
I can either tile before or after the door goes on but the gap with the tiles on first will still be too large for a standard door. It is a small room and needs to be a bi-fold door and I can't find the right size anywhere at a sensible price.
Will a wooden stud, tanked with Mapegum and then tiled work OK?
So if you tile first, then put the door on (this is how I would do it) how much gap would you have then? I don't like the idea of a tanked wooden batton.
Reply to Shower door in the UK Tiling Forum area at TilersForums.com
  • Sticky
Hi I’m fitting a Nova Frameless 1000 x 800 Sliding Door Shower Enclosure with a low profile...
Are there any BS standards covering this please I have recently had 3 sides of a shower tiled...
Shower door
