Discuss Shower fittings in the UK Tiling Forum area at TilersForums.com.
Gazzer
I have a job coming up this week where they have stripped the tiles off but the new tiles are a fair bit thicker than the old ones and that gives me a problem that the 2 threaded shower connectors wont protrude though the wall enough to get the 2 threaded chrome pips covers back on. Probably about 3-4mm too short now. I have 2 options so far, 1 grind 4mm off the old chrome covers or 2, replace with Talon pipe covers..... not sure if they would work though.
Any ideas ?
macten
1,158
Nottingham
The usual standard fittings are 2 x 3/4'' to 1/2'' off set z connectors that screw into 1/2'' female irons. If this is the case, which it should be unless a bar mixer installation kit has been used, then putting lots of ptfe on the 1/2'' end of the z connectors will allow you to gain the 4-5mm you need to screw the escutcheons on and be leak free.
Reply to Shower fittings in the UK Tiling Forum area at TilersForums.com
Hello, this is my first post so here goes, advice needed. It was decided that I should renovate...
Hi Tilers, this is my first question on this forum and I've got a few different areas to cover...
Hey all, first post, first time tiler... Throwing myself into the deep end, I'm about to rip...
Shower fittings
    Votes: 9 6.3%
    Votes: 13 9.0%
    Votes: 9 6.3%
    Votes: 44 30.6%
    Votes: 17 11.8%
    Votes: 34 23.6%
    Votes: 3 2.1%
    Votes: 20 13.9%
    Votes: 18 12.5%
    Votes: 15 10.4%
    Votes: 7 4.9%
    Votes: 3 2.1%
    Votes: 4 2.8%
