SPQR Tiling
G'day guys, im tiling a shower floor that has been screeded with a 15 mm fall and a shower grate. The shower grate is 100mm from the wall at 12 o'clock to the grate, and 50mm from the walls either side at 3 and 9 o'clock respectivley, and ive never installed one of these before and would greatly appreciate some advice?
the 100mm space of floor between the wall and grate i noticed follows the same fall as the entire floor and hasnt been angled to flow back into the grate, so water will accumalate there? will i need create a fall with adhesive in that one space?
How about those 50mm tiles on either side of the grate? if i angle those 100mm pieces of tile between wall and grate to flow back into the grate then what sould i do with those 50mm pieces?
they are 300 x 600 porcelain tiles by the way.
Cheers guys.
Cheers guys.
