Discuss shower panel boards in the Australia Tiling Forum area at TilersForums.com.
Just Wonderer if many of you had fitted these around a shower unit.... I'm doing a job this week and it involves tiling half way up the room all the way round and all the shower area....
They have now decided against the shower area been tiled and bought splashbacks
They have got 2 for the area needed around the shower tray which is 1200x1000
My questions are
Are they easy to install
Are they easy to drill through when putting shower panals and unit up
Do they sit on top of the shower tray like a tile would when you make your cuts
Cheers guys I'm just researching them now
How'd you get on with this?
We do full bathroom refurbishments and often against our better judgement the client will insist on this guff!
Kardean as well too Ray [emoji6]
Make sure the tray is perfectly level and if you need to cut the sheet that it is at the top, check how plumb the internals are as the outside/inside trim will give you less than 5mm tolerance.
Never use the shower seal supplied as like the tile version it is only going to induce water ingress through time.
Bond all edges and allow to dry, then plenty Silicon (on all trims too) on tray before dropping board in, wipe off excess then uniform 5mm bead next day.
Really easy to core MDF too,
Cut with a circular or hand saw.
dave l and l
There a a few companies fitting them round here.also seen a couple of ones getting ripped out as water has got into the ply base.
The m d f ones are terrible if they let water in what so ever....
Fitted the foam plastic ones but they seemed really flexible...easy to fit right enough.
They seem to be getting more popular
Reply to shower panel boards in the Australia Tiling Forum area at TilersForums.com
  • Sticky
Hi all, probably a pretty common question but I'm going around in circles looking online for a...
I'm hoping someone here can give me some advice! I'm re-tiling my shower after needing to rip...
Darlington
shower panel boards
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
