starvinmarvin
Hi all....
This is my first post as i've been lurking in the background so to speak. I need some advice if possible on my shower room floor install....Its a metre squared shower room in my basement flat which has been suitably tanked. I've got a centrally located trap / drain with adequate fall....but the problem is that I need to know what materials to use under the tiles? as i'm not sure normal adhesive will cut it?? I'm sure it won't?
I've got small 950 x 950 tiles to use:
Would these butt straight up to the trap? Which grout should I use? Any general advice would be great!!
Thank you in advance.
Starvin.
Starvin.
