Discuss Shower tray in the British & UK Tiling Forum area at TilersForums.com.
Deleted member 1779
I guess you are asking (but just forgot!) the question...
"How do I do it"
Fast answer.... Click this link
F
frogeye
The short answer to your question Dave - is with great difficulty.
Unless you are very lucky.
Been there and done that. The job was to simply remove old shower tray and fit a bigger new one without disturbing the old tiles. Sounds familiar?
On removal of the shower cubicle and tray I found out why it was leaking. The walls weren't square and the tray was out from the wall by nearly 20mm. Tubes of various Silicon and quadrant pieces had been used to cover this but without success.
Then there was the question of the waste, it needed to be realigned because of the new tray.
In the end we removed the affected plasterboard, built a new shower enclosure in 3 x 2 battens and green plasterboard about 3" out on both sides ( This made it easier to use different tiles by making it a feature and not have to worry about matching to poorly tiled walls). Reinforced floor with 18mm ply, resited waste and water inlet to shower and provided a trap door in kitchen (only way to do it) for access to trap and an isolation valve in case of emergency.
Sorry if this isn't what you wanted to hear but I hope you have better luck on a quick fix than I did. I can post some piuctures if of use
frogeye
cornish dave
Thanks they have a surface mount shower tray and don't want a access panel in the kitchen ceiling, and would have to break into the box for the stack for strap on boss in the kitchen they said no. so will put on a stand the tray is a round corner so will have to find something to put round the bottom thanks for all your help
Reply to Shower tray in the British & UK Tiling Forum area at TilersForums.com
Hello All, I have a shower tray installed and it is sitting away from the wall. I am going to...
Hi, I'm looking for some advice on the best method to level my ensuite floor. The floor is...
Shower tray
    Votes: 9 5.2%
    Votes: 17 9.9%
    Votes: 12 7.0%
    Votes: 49 28.5%
    Votes: 21 12.2%
    Votes: 40 23.3%
    Votes: 4 2.3%
    Votes: 5 2.9%
    Votes: 24 14.0%
    Votes: 19 11.0%
    Votes: 17 9.9%
    Votes: 8 4.7%
    Votes: 5 2.9%
