Guest viewing is limited
Discuss Shower tray in the UK Tiling Forum area at TilersForums.com.
peckers
I wouldnt use the edging strip it looks cheap and nasty, tends to leak after a while it always seems to deform and water gets under it.
I would fitt the tray and then silicone seal between the tray and wall, fill the gap so as it is level with top of tray and then smooth over with finger using water mixed with fairy liquid.
then tile leaving approx 3mm gap between tray and tile then grout and then fill the 3mm gap with a second layer of silicone and then finish it off with your finger again and a water/fairy liquid mix.
But I would also tank the plasterboard walls as well!!!:thumbsup:
Gazebo
I agree with peckers, CDS and scottley.
Tank plasterboard 1st then silicone tray into position, clean up any silicone that may affect the bottom tile, Then tile using the correct adhesive and solid bed method.
Then grout,, wait 48hours, then silicone perimeter joint between tray and tiles and also any vertical wall joints between tiles.
Leave to dry for 24 hours
Fit shower door/screen/enclosure as per manufactures instructions.
Leave silicone to dry again for minimum of 24hours.
Then get in that shower and get wet....
Good luck
Gary
[email protected]
Reply to Shower tray in the UK Tiling Forum area at TilersForums.com
Hello All, I have a shower tray installed and it is sitting away from the wall. I am going to...
Hi, first timers here... I am tiling my bathrooms and prefer the look & neatness of tiling...
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
Would anybody have any advice the best way to silicone these bumpy tiles. I think doing a bead...
Shower tray
