Discuss Signal generator amplifier using only positive pole output, underperforming Electrical Advice in the Electrical Advice area at TilersForums.com.
Signal generator amplifier using only positive pole output, underperforming Discussion ThreadSignal generator amplifier using only positive pole output, underperforming Electrical Advice
I have a 100W 50 ohms signal generator amplifier with a 35 meters coil wire (1.5 mm) as a load, BNC connectors. The requirement is that only the BNC POSITIVE pole is connected to the wire and used as antenna. The amplifier require a minimum of 4 ohms load. This is not a closed circuit antenna, although the negative pole touches the end of the antenna, isolated electrically.... yet no closed circuit. The problem is that I'm consuming only 10W (tested with a Tuya socket) out of maxim 100W capacity, and the amplifier's radiator is heating normally to overheating. It does the job, but how can I get more juice out of it, not only 10W measured output ?
Signal generator amplifier using only positive pole output, underperforming for the original thread on Electricians Forums
Reply to Signal generator amplifier using only positive pole output, underperforming Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
