Discuss Silence Is Golden With Bal Acousti-bond in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
SILENCE IS GOLDEN WITH BAL ACOUSTI-BOND
Acousti-Bond is a new acoustic floor tiling adhesive, which is accepted by NHBC for sound insulation in housing applications, when used as part of a impact sound reduction system.
Recently addressed by changes to Part E of the Building Regulations, sound insulation is a key concern for house builders and the designers of hotels and apartments. Most types of dwelling nowadays contain increasing numbers of noise-producing appliances, while on the other hand the desire for peace and quiet has never been higher.
BAL Acousti-Bond is an elastomeric single-part adhesive which is accepted by NHBC for use with an approved matting system such as Regupol 4515 acoustic matting and an approved flooring adhesive such as Ardex AF200. BAL Acousti-Bond has been developed to achieve excellent adhesion to acoustic matting without adversely affecting the sound reduction performance of the floor. It performs in this way due to its formulation, which contains similar fillers to the materials used in acoustic mattings. These specially selected fillers give improved acoustic properties, compared to conventional tile adhesives, which contain more brittle types of fillers such as sand which can help to transmit sound.
When used as part of a system, BAL Acousti-Bond also provides a lightweight solution, which is particularly desirable when used on suspended flooring.
“This is an excellent new product line from BAL,” says David Longwell, Chief Chemist, “which has been the subject of extensive testing and development. The fixer feedback from trials has been excellent, so I’m confident that this will be a popular system, which shows BAL innovation at its strongest and provides a demonstrable end-user benefit.”
BAL Acousti-Bond has been the subject of extensive installation trials carried out on recent projects. These include Trinity One Apartments in Leeds and Shoebury Garrison in Southend on Sea, as well as in-house testing at the Building Adhesives Enfield Training Centre. Based on test results from these trials, the NHBC have accepted the use of BAL Acousti-Bond as part of a system to achieve the performance requirements of Part E of the Building Regulations 2000, Resistance to the Passage of Sound.
BAL Acousti-Bond benefits from the standard BAL ten-year guarantee and is fast-setting in use and can be used with any flexible grout, such as BAL Superflex Widejoint Grout. It is available in a 7.5kg bag.
............dave..
DHTiling
Exactly the type of product that Acousti-bond is designed for use with is regupol products.....dave..
Regupol 3912
Regupol 3912 is a compound and dampening pad made from a combination of PUR bound polyether foam and rubber granules.
Regupol 3912 is an acoustic underlaying material which helps to provide impact insulation for various types of floor finishes, for both residential and commercial applications.
Suitable for new build and refurbishment projects.
Roll width: 1.00m
Roll length: 15.00m
Material Thickness: 6mm
Laying: Convex side upwards
Compliance Tested to: Document E 2003
Regupol 4515
Regupol 4515 is a tough, durable acoustic underlay material to attenuate impact sound at source. It can be bonded to all types of base floors using an approved adhesive.
It is suitable for all floor finishes including ceramic tiles, sheet vinyl & vinyl tiles, wood and laminates, carpet & marmoleum/linoleum.
Roll width: 1.00m
Roll length: 18.00m
Material Thickness: 3mm & 4.5mm
Regupol is a sound insulation material used for underfloor impact sound reduction. It is made from recycled rubber and cork with a polyurethane binder, and is suitable for use under most floor finishes, as well as between structural floor elements.
Regupol is an excellent use of recycled rubber. It is supplied in rolls of 3mm and 5mm thicknesses and is easy to install. It is temperature resistant from - 40 °C up to +110°C.
Regupol can be used to reduce noise on stairs (5mm recommended) and impact sound from hard floor finishes. It can be installed in strips on top of joists, or in rolls between floor elements to minimise the transmission of impact noise from above to below. It can also be used as a carpet underlay.
Under ceramic tiles
The 5mm thickness of Regupol should be used, fixed to the base floor with a flexible cement adhesive. The ceramic tiles should then be fixed on top of the Regupol with flexible cement adhesive, and grouted with a flexible grout.
Reply to Silence Is Golden With Bal Acousti-bond in the British & UK Tiling Forum area at TilersForums.com
We are having some issues with our newly laid tiles. Within several weeks of being laid, we...
5K
David John
I received an email about BAL External tile adhesive and grout this morning and thought I'd post...
5K
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
