Discuss Silicon edge of room in the British & UK Tiling Forum area at TilersForums.com.
F
FreeD
Hi all
Think i've done something wrong and need to be enlightened to the correct method...
last job i did i left a 10mm expansion joint around the room between the tile and skirting...then grouted this line with flexible grout...then siliconed between grout and skirting.
I had problems with the PCI Silicon going off...i had waited for the grout to dry before siliconing...the PCI Silicon still hadn't cured after 72 hours...a phone call to technical revealed that the Silicon was 3 years out of date and they thought this may have been the problem...but the shop i bought it from say that PCI have since done tests on the same batch and it was fine (they showed me cured Silicon) i told them well i left mine 72 hours and it was still uncured could this be my fault something to so with siliconing between wood and grout?
Anyway i read on the forum that if tiling up to skirting then only a 4mm gap needs to be left not 10mm and that this is not filled with grout first but filled with Silicon???
L
LM Ceramics
10 mm is to big of an expansion gap like dave says 4mm is suffiecent grouting the expansion gap then siliconing the gap defeats the object really the whole point of an expansion gap is the leave a joint for expansion
i always Silicon internal corners leave them un grouted also another tip is what i hear if there ever a failure on the adhesive that is one of the things they will check if the corners have been siliconed
Tiler Dave
when tiling bathrooms, or any where really after grouting and cleaning up i usually silicon all my internal corners just to ensure water tightness. weather tiling onto stud work walls which may move or solid walls which are less likly to cause probs. this i do as a rule in showers and other water prone areas....
Reply to Silicon edge of room in the British & UK Tiling Forum area at TilersForums.com
Been advised to move this post to the uk forum, didn’t realise it was in the USA forum Would...
gamer1
  • Sticky
    Votes: 14 9.3%
    Votes: 11 7.3%
    Votes: 44 29.1%
    Votes: 18 11.9%
    Votes: 36 23.8%
    Votes: 21 13.9%
    Votes: 18 11.9%
    Votes: 16 10.6%
    Votes: 7 4.6%
    Votes: 4 2.6%
