Guest viewing is limited
Discuss Silione seal in a corner with anti slip floor tiles. in the Best Floor Tiles area at TilersForums.com.
cornish_crofter
I will have ceramic tiles coming down onto prcelein floor tiles. However the floor tiles have and anti slip surface on them.
Going about sealing the way I normally do will give me a problem. The anti slip surface (loads of small diamond protrusions on them) will snag the Silicon.
Can anyone think of another way. The bottom row of wall tiles are not fixed yet.
I was thinking of leaving a 3mm gap and grouting in the corner where the wall and floor tiles meet, then using clear Silicon over it. That way the sngged Silicon wouldn't be too visable.
cornish_crofter
Thanks both of you.
Dave, leaving traiing bits is going to be impossible to avoid. It's not a sandpaper like surface but the surface of the tile is anti slip. That is to say that there are little diamonds over the whole tile. These are about 2mm high.
Siliconing the corners in the conventional way will leave me with another problem as well. The diamond tips will be wanting to burst out of the radius of the joint.
Paul, I like your idea but it sounds expensive, and finding a dark grey Silicon the same colour as the tiles is not going to be easy as I live on the Devon/Cornwall boarder and the main suppliers seem to think we don't exist.
tfs
You could also make skirting from the floor tile to put over the sealant.
Another alternative could be to use internal expansion strips if you can get any localy.
Reply to Silione seal in a corner with anti slip floor tiles. in the Best Floor Tiles area at TilersForums.com
  • Sticky
My mum is having her bathroom fitted and she sent me some photos and my partner pointed out that...
5K
Hi I am after some advice and opinion if the quality of our recently installed tiles is of an...
Greetings All, appreciate the expertise existing in this forum. I am a home remodeler, not a...
5K
Hello guys I’m looking for some advice I will be attempting to redecorate my living room which...
Best Floor Tiles
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
