Discuss Skimmed walls and drying in the British & UK Tiling Forum area at TilersForums.com.
K
kaharrison9
Hi All
Hoping for your thoughts
Been taking the tiles off today from a 20ft long bathroom that was planned for starting tiling on Monday.
The previous tiler had dot and dabbed the entire bathroom and in areas the tiles were about 10mm off the wall.Not possible to tile directly onto the old plaster as the walls are very uneven.
For reasons cannot overboard and the customer is totally understanding in that it needs skimming/levelling before i can tile.
Tonight he has a plasterer(mate of plumber)coming round to quote for the work.
The plumber is sure if his mate can skim on Saturday we should be fine to carry on Monday.
This seems very quick to me.
Been looking at previous posts and should i work on this 24h drying per mm,or is there any other way or should a couple of days be fine?
The plumbers a funny one,cannot understand while i'm using cement adhesive when his mate would use tubbed and so on.
Have no experience yet on deciding drying times while also holding off a guy who seems to want to get in and off.
Any views appreciated
Cheers
Kev
Aztectiler
Using a heater to dry out plaster is not the best way to dry it, to force dry the plaster skim may indeed crack and release from its bond on the wall (not always so but has been known) better to let the plaster dry naturally and wait to do the job. Remember that the plaster has done his job and client will be happy with him, it then becomes your responsibility when you start the job, if something does happen then you know that all will say "It was fine before the tiler started"
Patience is the virtue in my opinion. Good luck.
K
kaharrison9
I see what your saying Doug regarding skimming making know differance.
The plumber explained to the customer his mate would have it flat.
I don't know enough on plastering to query him.
Regarding re-boarding/overboarding the customer is keeping his old bath and if it was overboarded,plus with a tile it would create a small overhang and i don't think he would be able to turn the taps.
Also should have mentioned the 2 long walls were divided half by tiles and half paint by a very old ornate rail the customer has stressed he wants and doesn't want it damaging.
As like the bath if overboarded plus a tile under the rail it would stand out.
Chieslling off the plastering as you guys say then reboard does make sense but nervous in case brings these rails down and how big a job is taking off plaster around baths and large areas.
Hope i make sense
Kev
K
kaharrison9
Update on this bathroom.
Stood my ground when the plasterer came round explaining skimming would make no differance,I put a 10ft baton along the walls and they were even further out,up to 18mm hollows.
The plasterers replies were,the hollows were within British tolerance,he'd seen lot worse in new houses and generally all tilers have to accept at times you have to dot and dab.
I mentioned flaws of dot/dabbing,amount of adhesive,safety,boarding out,etc and said i wasn't prepared to do the job.
Intially the customer gave him the job to skim but rang the next day,apologised and said he'd seeked further advice and was now having it boarded out by another guy whose taking the bath out to do behind and when he explained this to the plumber he was cut off while explaining there'd now be a slight delay to prep the walls.
Kev
Reply to Skimmed walls and drying in the British & UK Tiling Forum area at TilersForums.com
I started removing the tiles in my bathroom today and the majority of the plaster has come off...
Tikkaaa
Hi - we would very much appreciate some advice. In October 2020 we had a sole trader come in to...
  • Sticky
    Votes: 9 5.8%
    Votes: 15 9.7%
    Votes: 11 7.1%
    Votes: 45 29.0%
    Votes: 19 12.3%
    Votes: 37 23.9%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.6%
    Votes: 17 11.0%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
