Discuss Skirting tile cutting on a Sigma in the Canada Tile Advice area at TilersForums.com.
Jeff the tiler
Just had a load of 60 x 30 150mm skirting to cut (and its probably me) and can only say it is the first down side to my Sigma, but can not seem to get a exact match using the Swivel measurement bar along with the square attachment. I have had to mark every tile to get straight matching cut as each tile i tried to cut in half using the guide an square seem to differ. Any suggestions or are you finding the same.
peteablard
1,058
Cheshire
You could buy a Rubi:sofahide:
Jeff the tiler
Dave agree with comments, just have had to mark top and bottom of each tile to get a half cut which was good. Maybe the measuring guard out slightly is the only thing i could put it down to as the 0 point is not 100% precise though kept try to adjust slightly but it could also be as the square is only short there could be slight movement when scribing as I have the push version hence the post to see if anyone has had the same.
Reply to Skirting tile cutting on a Sigma in the Canada Tile Advice area at TilersForums.com
Hello, I hope you can help. I'm get despondent cutting 9mm glazed porcelain tiles, 300 x 900mm...
Hi, I'm new to the forum and fairly new to tiling, my only previous "proper" job was my recent...
    Votes: 6 4.5%
    Votes: 11 8.3%
    Votes: 8 6.1%
    Votes: 38 28.8%
    Votes: 16 12.1%
    Votes: 32 24.2%
    Votes: 3 2.3%
    Votes: 2 1.5%
    Votes: 19 14.4%
    Votes: 18 13.6%
    Votes: 15 11.4%
    Votes: 7 5.3%
    Votes: 3 2.3%
    Votes: 2 1.5%
