Discuss Skirting tiles & fitting uncoupling membrane in the Australia Tiling Forum area at TilersForums.com.
On one
Hi All. I need a hand with pricing a job please.
A 130m2 of 300mm x 300mm porcelain tiles on a heated concrete floor in 4 different rooms. That isn't a problem pricing wise,but I could do with a hand pricing,laying 130m2 of uncoupling membrane and 80 linear metres of skirting tiles.(labour only)
So if you wouldn't mind chucking in your pennysworth it would be appreciated.
Sounds full on! 10mins for 1.2m!
130m2 to scrape,clean, sweep and maybe prime, that's not an hours work I know!
8m2 ish is probably one mix, if ur using rapid, sorry if I was using rapid I would want my bucket washed completely clean between mixes. (Otherwise shorter lot life time next mix)
Then the Ditra has to be rolled out cut and trimmed in possibly (if its multi room that's a fair bit of trimming) then tamped or rolled into the adhesive air extracted.
Are the joints taped? That's not a five min job if done correctly with Kerdi Coll.
I'm assuming @Dan that calculation applies to the whole day without any kind of break?
Not saying it can't be done obviously, I can't, its just an observation.
I also tend to use any little extra I make on installing Ditra for those silly hidden extras haha
Not disputing any of the above advice at all!
Just running the job past myself, out loud!:D
Do u have to cut skirting a from main floor tiles?
How are u finishing the top edge, trim, grout, Silicon, something else?
If it's trim, how many mitres do u have to cut at transitions?
External corners are there many?
Are they mitred tiles or trim or butted up?
Are the wall lines good? (Flat) is there packing out/up to do?
Then there's Silicon between floor and skirting transition to do.
Just little things that often slip your mind when quoting I think.
Spare Tool
Hmmm now you put it like that think I underestimated, was just thinking about mixing and rolling out the ditra, good half a day in cleaning n priming. Could be nearer 3 days before you get a tile down with setting out..
I take it all back Diggy :)
On one
Hi 3-Fall. I see where your coming from......just like a prospective customer ringing you up out of the blue and asking what your £m2 is?
Hope the following helps you,to help me!
The skirting will be cut from the main tiles
No trims,just a grout finish to the top.
No external corners only internal corners,butted up,
Walls are good,
Siliconing,I am pricing as a separate item.
I thought I already tried to help! Haha
Asking u to break down the job into individual items so that u can put a time scale to it.
Personally tho, to fit ready made skirting tiles, not ones I have to fabricate labour only I'd be pretty close to the fivers people have already mentioned. I'd probably want more to make them as well!
I find when pricing I do the job in my head first, in the smallest of detail that I can, and break it down that way.
I find I'm less likely to make mistakes.
There's so much we do automatically in our job it's easy to overlook when pricing.
Just think it through and don't cut corners, your price is what it is mate, if u sell it right and convince them your the only guy on the planet capable of doing it, won't matter bout the price!
YOU CAN COME DOWN, YOU TRY GOING BACK UP! :)
m3fitter
Ditra £5.00 a metre labour / adhesive 1 bag per 10 sq.metres based on 6mm notch
bespoke cut & fix skirtings with trim labour @ £8.00 per linear metre
this is a normal cost, even for the Big boys Berkeleys, Millgate etc..
As a rule, if the project is over 5k, then start looking at the overall margin, as opposed to sq.metre margin.. as they will ;-)
AliGage
Subscribed
4,531
1,188
Peterborough, England
Just spotted this. 3_fall and I did an 80sqm plank with tiled skirts. Ditra too with it up behind the skirts and banded with kerdi coll. It's not as quick to get down as you may think.
Long runs also increase the chances if air pockets under the ditra too. So factor in a roller (purchase ir hire) ad they come in very handy.
Reply to Skirting tiles & fitting uncoupling membrane in the Australia Tiling Forum area at TilersForums.com
I'm embarking on tiling a kitchen, wall-to-wall (under washing machine etc). most of the floor...
Apologies in advance. This question might be asked a lot. My new house is due completion in May...
benchwarmer
Hi all, I would appreciate some professional advice please. I have 10mm porcelain tiles for a...
Hi Ive been browsing your forums over the years looking for guidance for odd tiling DIY tasks...
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
