F
finnmccool
Hello I'm about to lay a slate floor on 18m WPB plywood, I will be using the usual flexible adhesive & grout' but have been advised that this is sometimes not enough & that I should prime the surface before tiling' or risk the slate lifting.
Does anyone have any advice on which primer I should use?
The last slate floor I did some time ago' had underfloor heating' a and I used a heat reflective floor primer and have had no problems' but this may be more luck than judgement!
Ciaran
Ciaran
