mmmadman
Hi all, this is my 1st post on this great site.
I started laying an 18m sq slate patio on my existing 600 x 600 concrete slabbed patio which has been down for years. I am using 300 x 300 x 10 natural slate from Wickes and I am creating a pattern with diamonds and small squares. Joint size is approx 10mm.
The Problem
Day 1, I laid three rows using a bed of approx 10mm sand and cement 5-1 wet mix (recommended by a builder mate)
Day 2 I started the pattern and laid about a third of the total area, using the same mix.
On day 3 I went outside and it was raining a bit and I noticed that some of the tiles that I had laid on day 1 moved when I stepped on them and I was able to lift them by hand too. The tiles that I laid on day 2 seemd ok but I did not lift any.
Now one week later all of the area I did last week seems firmly bonded except the ones that I actually lifted that were laid on day 1.
Were the tiles still curing and is it ok to leave them now or do I have to take it all up and use a prority adhesive? what happend?
I intend to seal and then grout with the correct grout not mortar.
I hope I hav explained the problem ok, many thanks............
The Problem
