Discuss SLC over a heat mat...... in the Canada Tile Advice area at TilersForums.com.
Andy Allen
1,318
Gloucester
What you lot using to cover your heat mats...??
I'm struggling to get hold of my normal Weber floor flex...
Also, talking to my supplier he was working out for a 23m2 floor I would need 7 bags ?
I normally work on getting 2m2 per bag...?
Albert
1,253
Gateshead NE8, UK
Me too
Spare Tool
Is it still easy to use....?
Keep getting vision's of it going off before get chance to level it..
Its fine at this time of year, just gotta be all set up with plenty of water at the ready in the summer and don't stop mixing and pouring till whole floors done..
For leveling over ufh i use 1" strips of 6mm insulation boards, stuck to level or flat with ady and split floor into 1m wide runs over ufh mats, just pour a load in at one end and pull 4ft level over strips...
Reply to SLC over a heat mat...... in the Canada Tile Advice area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
I am sure someone will know a good practice solution. We started a wetroom last year and then...
gamer1
Andy Allen
Gloucester
    Votes: 14 9.5%
    Votes: 44 29.7%
    Votes: 17 11.5%
    Votes: 35 23.6%
    Votes: 21 14.2%
    Votes: 15 10.1%
