Discuss SLC Over ufh cables in the British & UK Tiling Forum area at TilersForums.com.
DHTiling
Some spec for you rich..
broken link removed
Water-bored ultra-fast hardening self levelling fibre reinforced smoothing compound.
Applications:
Fiberplan is used for smoothing and levelling from 3 to 10 mm over adequately anchored wood substrates and wooden boarding where good resistance to loads and traffic is required; Fiberplan is suitable for wheeled chair traffic and for heated floors.
Fiberplan can only be used internally.
Smoothing of old and new timber floors: wooden boarding, chip-board panels, plywood, parquet.
Smoothing cement, terrazzo, old ceramic tile, natural stone substrates. Coverage
1.6 kg/m2 per mm of thickness. Packaging
25 kg bags.
Gazzer
A little tip, if you spread your adhesive with a 4mm trowel and then roll the matting into this it will hold the mat down and helps stop the floating of the heating mats when you do your SLC pour.
Oh and make sure its flexi adhesive suitable for UFH and when using this method, fast set flexi adhesive is best unless you can leave it overnight before the SLC
Richardk
It's loose wire rather than mats and I'm planning on using a hot melt glue gun to stop the cable floating in the slc. I'm planning on using Keraquick to fix the insulation boards to the timber floor, and keraquick to fix the tiles to the slc. I'm not used to Mapei so still learning which products to use. The Fibreplan is a bit dear isnt it, about twice the price of what I would normally use.
grumpygrouter
Would be better to use Latex Plus additive as well if it's on a timber floor.
Reply to SLC Over ufh cables in the British & UK Tiling Forum area at TilersForums.com
Hi I asked the Wunda technical department if I can just use a Ditra mat only and not the SLC...
Further to my other post re our hollow tiles issue It looks like our tiler has dot and dabbed...
hello new here but wished i had found and asked before screed and ufh down but here goes. We...
SLC Over ufh cables
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
