moe
Hi All,
I would appreciate some advise on my bathroom project. It's a 1930s 9" solid brick block wall. The bathroom has two internal and two external facing walls. The internal walls have standard plasterboard finished with multifinish One of the external walls is cement rendered except on the wooden window lintels, the other which is next to the bath is half lime render/half cement render. I've stripped off the gypsum plaster on the external walls and am unsure how to proceed.
Should I patch up the lime render with limelite/Hardwall and straighten the lot with multifinish or do I need to remove the lime render altogether, being external walls I'm concerned about condensation.
TIA
TIA
