Discuss some new technical knowledge........not in the British & UK Tiling Forum area at TilersForums.com.
Spud
found out today from a builder that it wasnt the fact that his guys had dot and dabbed( 5 small spots) 60x60 porcelain tiles on 12mm plywood walls that all his tiles had come loose and failed it was actually because the client had turned off the air control unit in the pool house that had caused the failure of his tile installation ,how does that cause tiles to fail I asked its is the excess moisture which causes movement I was told, okay thanks for the info I will pass it on to the british standards institute :mad2:
Diamond Pool Finishers
he might be partially right ,i have seen the complete insides of pool-rooms destroyed by the de-humidifacation unit being turn off for a long period of time and keeping the swimming pool running Gary!
and moisture/ water causes expansion thus movement at different rates in different materials ! but having said that it is probs poor fixing practice
Spud
Thanks Gooner,the pool room is showing signs of movement but at the time of the build only 3 years ago I did mention to the builder that he should use hardi backer to line his walls and use a 2 part tile adhesive ,I was told to mind my own business and the builder tried to get me kicked off the job,The client asked me to tile his bathrooms which i insisted should be hardi backer and the builder accused me of trying to waste the customers money I will post some pictures of his work tomorrow to see what you think
Reply to some new technical knowledge........not in the British & UK Tiling Forum area at TilersForums.com
DIY SOS. Helping people without time or money, in need desperate need to get a project...
5K
Hi all, Just had the bathroom floor tiled - well almost , the builder walked off after a...
7K
StevieBoy
So.... Signed up to the forum, looked at loads of threads (found the one about poor workmanship...
Hi guys. Bit of a strange one this. Had a query from someone who has had tilers fitted by a...
6K
bcd-87
Hi All, We had a new bathroom fitted just over 2 months including new floor and wall tiles...
White Room
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
