pipeline
evening all... i havn't posted on here for a while, but picked up some work with a bathroom fitter and it has got me thinking and ive got some questions..
question 1. can u use self leveling compound over plywood floor, i recently tiled my bathroom floor. by overboarding it first with 12mm ply and there was a slight bump in it. the bump was where the floor boards run over the joist,, but it was nothing u could noticed after being tiled.. so i thought maybe i could of used leveling compound first,, or should i of sanded the high spot out of the floor first?.. or doesnt it matter if there is a slight bump.
question 2. what is the differnce between rubi ts and ts plus. and which 1 is better
question 3. when going to a job and finding u are using large format tiles 600mm ect,, and the walls are sand and cement render,, and skimmed in gypsum.. how do u go about setting the room up so it conforms to weights and measures..
qestion 4.. can i use dri wall adhesive to fix aqua board.
thanks again... merry christmas
