59peejay
Have just picked up some Porcelanosa Multicolor Nacar 20x31.6x1cm tiles that imitate the mosaic effect,mosaics end up at 4x4cm in size for Mothers kitchen splashback.Saw these laid on a kitchen display in the M/cr showroom and thought they were proper mosaics so i know if laid right can look like the real thing.
The factory cut grout lines are about 1.5mm wide,will i be ok with 2mm spacers?,i would imagine that unless i struck the joints really hard there will be a little spread that will take me to around 2mm,also should i lay them one over the other keeping the main grout line in-line or stagger them,bearing in mind most of the job will only be 16-18" high apart from up to the extractor.
After applying primer g to walls i normally use a tubbed addy for these small jobs(ultimate grab by Mapei for bnq) how long to leave before grouting,i am in no rush?,thanks.
