Discuss Special Tile edging in the Canada Tile Advice area at TilersForums.com.
I'm undertaking a little tiling project and will need to incorporate some edging. There is an existing tile job in our house that utilized a piece of edging I have never seen before and the tile store I spoke to had never seen before either. The edging is like an L edge but the lip is extended ~1/2" allowing you to tuck the end of the tile under the edging hiding the cut edge (instead of an L it becomes a U). I thought this is a great idea, saves you from having to cut every tile the perfect size. Has anyone heard of these? I can't find them online. I will upload a picture if I can figure out how.
Reply to Special Tile edging in the Canada Tile Advice area at TilersForums.com
Ok I am fitting the tile trim L shaped aluminium profile around the window, Dave you are right...
7K
HI, Walls are prepped, have the right materials and tools, but still debating the layout on...
Is there a technique and a tool that you guys recommended that can be used to smooth out any...
Dougs Third Go
Canada
What member type are you?
  1. Homeowner
Special Tile edging
    Votes: 5 4.7%
    Votes: 8 7.5%
    Votes: 6 5.6%
    Votes: 29 27.1%
    Votes: 14 13.1%
    Votes: 27 25.2%
    Votes: 3 2.8%
    Votes: 2 1.9%
    Votes: 19 17.8%
    Votes: 18 16.8%
    Votes: 13 12.1%
    Votes: 5 4.7%
    Votes: 3 2.8%
    Votes: 1 0.9%
