Discuss Splayed or irregular corners in the British & UK Tiling Forum area at TilersForums.com.
BTB
Tiling a downstairs WC at the moment and due to a past garage conversion, one wall has a rounded angle of around 135 degrees.
I am tiling brick bond and obviously can't go across the angle because the wall would need building out to square it off which the client does not want (loss of space which is at a premium).
So I am thinking that a straight joint is the only option, which is a shame from a visual point of view.
Would you just Silicon the straight joint or perhaps put some kind of chrome trim in to highlight it?
Tiles are just standard ceramics 360x240.
I have tried to attach a piccie and will add more as I progress
jay
hi by rounded angle you mean just at angle not wall either side as long as walls are flat cant see why b/bond cant be done as long as you place a vertical joint were wall angle starts like internal if you have no cracks in wall at angle you could pos get away with just grout id recomend Silicon to be sure hope that makes sence :8: you could ron a/angle (used at door stops to meet carpett) just to give a good visual effect
Reply to Splayed or irregular corners in the British & UK Tiling Forum area at TilersForums.com
Hi, I am in the process of tiling with subways and just wanted some help with corners, if trim...
  • Sticky
Hi My builder has tiled my bathroom with bevelled tiles but I am left with an external corner...
WetSaw
Hi Everyone - I'm new here, please be gentle. I am just about to start to tile a new extension...
5K
F
We have a bathroom company in at the moment. We have concerns about the tiling. To me, it looks...
7K
SJPurdy
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
