jonnyc
JUST LAID A PIETRA SERENA SANDSTONE FLOOR IN A KITCHEN.
IT WAS PRESEALED THREE TIMES WITH STAINSTOP BY A DRYING AND SEALING COMPANY, SO STONE WAS DRY WHEN SEALED.
LAID STONE IN PCI CARRAMINT ADHESIVE WHICH IS RAPID SET WITH NEW LOCK IN MOISTURE TECHNOLOGY SO NOTHING MIGRATES THROUGH STONE TO SURFACE.
SO FAR SO GOOD.
WANTED TO GROUT STONE WITH GROUT THAT HAD NO ADDITIVE BUT COLOUR WAS NOT APPROVED.
INSTEAD HAD TO GROUT WITH ARDEX FS CAST IRON AND DOVE GREY PROPORTIONALLY MIXED TO APPROVED COLOUR.
DID SWISS DOUBLE GROUTING , COVERING WHOLE FACE OF TILE FIRST TIME AND ONLY JOINTS SECOND TIME TO MAKLE FLUSH.
FLOOR WAS VERY WELL WASHED AND ALL LOOKED EVEN.
CAME BACK NEXT DAY AND THERE IS 50-70 MM WIDE DARK STRIP EACH SIDE OF JOINT.
DOESNT LOOK OR FEEL LIKE GROUT STAIN SO THOUGHT IT COULD BE MOISTURE WORKED IN TO FACE OF TILE WHEN GROUTING.
THIS STONE WAS STILL A BIT POROUS EVEN THOUGH PRESEALED THREE TIMES.
SO LEFT FLOOR A WEEK AND CAME BACK YESTERDAY TO SEE IF HAD CHANGED.
STILL THE SAME.
SO APPLIED POWER CLEAN IN CASE GROUT RESIDUE AND SCRUBBED. DRIED TILE WITH HAIR DRYER BUT STAIN STILL THERE.
I WILL GO BACK WITH DAMP METER BUT NOW WORRIED THAT STONE HAS STAINED.
I HAVE ALSO PLACED A STONE NOT FIXED NEXT TO FIXED STONE AND IT IS MUCH LIGHTER IN COLOUR EVEN LIGHTER THAN THAN MIDDLE OF FIXED STONE THAT HAD ONLY ONE LOT OF GROUT ON IT.
STRANGe THING IS THAT HAVE TRIED GROUTING OVEDR FACE OF A LOOSE TILE YESTERDAY. LEFT FOR 30MINS AND WASHED OFF .
DRIED IN SUN AND NO STAINING AT ALL.
THIS DOES NOT LOOK LIKE THE NORMAL INGRESS OF MOISTURE THROUGH SIDE OF TILE (ie picture framing) WHICH YOU CAN GET WHEN GROUTING ASTONE THAT HAS ONLY HAD WATER BASED SEAL APPLIED.
WHEN THIS HAPPENS , IF LEFT A FEW DAYS PICTURE FRAME CAN EASILY BE REMOVED WITH WEXA SCRUB.
PIETRA SERENA IS NOTORIOUSLY TEMPERAMENTAL BUT I HAVE TAKEN EVERY PRECAUTION COULD THINK OF WHILST FIXING.
ANYONE GOT ANY IDEAS HOW TO GET RID OF MARKS
SO FAR SO GOOD.
STILL THE SAME.
