duncan_ellison
Hi all,
I'm doing a wetroom and when knocking off the old tiles the plasterboard is in such poor repair, I've decided to remove it and replace with Knauf Aquapanels.
Three sides of the room are on stud walls, so that presents no problems, but one has the plasterboard dot and dabbed onto medium density blockwork, which is a pig to get off. Using an SDS hammer drill and a wide chisel, I've managed to chisel off most of the old adhesive, but now I'm not sure of the best way to re-attach to Aquapanels to the blockwork.
Two main questions :
1) Is it really necessary to use mechanical fixings as well as adhesive ?
2) What adhesive would you use to stick the panels back up to the wall ?
Duncan
Duncan
