Discuss stone floor cleaning in the British & UK Tiling Forum area at TilersForums.com.
Hi Guys
I'm looking for a bit of advice regarding the best scrubber/cleaning machine for stone tiled floors.
I've just finished tiling a travertine floor at a clients house and she has asked me if I could clean 2 existing floors in other rooms. 1 is 70 mt black riven slate, sealed with lithofin slate seal (client thinks) and the other floor is a 55 mt pillowed edge limestone floor with some small pitting to the surface (not sure on sealer). Both floors are dirty due to kids/dogs/spillages/normal living conditions.
I've done some manual cleaning before but not on floors of this size. I'm assuming the best way will be to hire a scrubber but having never used one before I'm looking for your advice.How hard are they to use?What scrubbers do you guys use?Are there any tricks to doing it?
Also was going to use a lithofin dirt remover (maybe wexa) unless anyone can recommend something better?
Thanks in advance
Admin - please move this post to the cleaning and restoration section. thanks
SquareEyes
Hi monkey
Did you get any replies from your post? I'm sort of in the same situation now myself and those cleaning machines look like they cost a fortune!
Any info would be great if you wouldnt mind sharing it with us!
Joe
Hi Guys
Thanks in advance
Marble Life Ltd
Hi Guys
Thanks in advance
Both floors will need to be stripped back to the stone. The pitting is the stone rejecting the sealer. You will need a rotary scrubber machine with a soft to medium brush fitted and a good quality wet vacuum. Apply Sealing & Coating Remover to the floor in small sections making sure you mask off really well as the sealing & coating remover will strip any paint it comes into contact with so doors, skirting, kitchen units need to be really well masked. Then rinse each section with a pH neutral cleaner and finally rinse whole floor again and allow to dry for at least 24 but preferably 48 hours. Then re seal with new sealer when fully dry. Make sure the sealer is MVT (Breathable) and water based. HSS will hire you a scrubber and a wet Vac! Make sure the scrubber comes with a decent brush and a tank.
Kevin
MLL
Reply to stone floor cleaning in the British & UK Tiling Forum area at TilersForums.com
Hi, New to the forum. Have a tiler coming in to do my floor tiles but don't think he's done a...
stone tiler
Surrey and South East
Website
http://www.thetileemporium.com
Business Name
The Stone Tle Emporium
    Votes: 14 9.4%
    Votes: 44 29.5%
    Votes: 17 11.4%
    Votes: 35 23.5%
    Votes: 21 14.1%
    Votes: 18 12.1%
    Votes: 16 10.7%
