Discuss Straight row!!!!!!! in the British & UK Tiling Forum area at TilersForums.com.
crazysteve123
Hi guys i have recently tiled a hallway i started my first row from the door, the door was like a banana,what i really struggle with is getting my first row level really frustrates me and also the hallway goes into a passage way and when i set it out the tile should have ran along the skirting but when i got down there it was about two-three inches away looked a mess in my eyes, any tips on centreing a room, prevent tiles running out and datum lines etc would be great cheers...
Mike Strutter
I always meaure to find the centre point and dry lay tiles in every direction, that way i can tell if the walls are wonky and which position in relation to the centre mark to start. I always leave myself as big a cut as poss into the wall, never assume the walls are straight so never plan to run a whole tile along a wall. Cutting into the walls takes all the worry of being left with a small slither of tile, which as you said looks crap.
As Sir Ramic says get a set square, they are priceless, and draw onto the floor. Taking an hour or so setting out is time well spent if it means getting the floor to look right.:thumbsup:
The D
1 Using a measuring tape find the centre of the floor and mark using a pencil.
2 using that measurement mark the floor at the other end of the room (this should always be don on the longest straightest wall of the room)
3 Using a chalk line ping in the centre line between the marks.
4 Using a measuring tape find the centre of the floor length ways.
5 Using a preformed square and a chalk line ping in the cross hears.
6 Mark out a gauge rod by cutting a piece of wood to length and position the chosen tiles alongside the gauge rod.
Remember to include the chosen spacers.
Mark on the rod to indicate each tile joint
7 Using the gauge rod check the cuts width ways and mark the floor with a pencil to indicate the position of the tiles.
8 Using the gauge rod check the cuts length ways and mark the floor with a pencil to indicate the position of the tiles.
9 Using a measuring tape measure from the cross hears to the edge of the first full tile.
10 Transfer the measurement to the edge of the floor.
11 Transfer the measurement to the edge of the floor at the other end of the room. (You should now have a line at one end of the room that runs parallel to the centre line)
12 Using the appropriate adhesive fix the first row of tiles along the new line.
13 Cut and fix the tiles to the edges.
14 Using a measuring tape measure back two tiles.
15 Transfer the measurement to both sides of the floor.
16 Using a chalk line ping in the line.
17 Fix the next two rows of tiles up to the chalk line and cut the tiles to the sides.
18 Repeat the process to completion.
smurf21
measure accross the door or hall and find the centre mark the floor. then from the same wall measure the same, mark the floor.(about six foot further down hall way.) and ping a chalk line. stand at the entrance and look down the line to see if its running true to centre if so the use your square of this line into other areas. if you dont have a square then use tape and 3/4/5 it to find the square i.e 3' from fixed point on line. 4' at a 90 degree angle from fixed point ping line between the two then from the 3' mark on the line measure 5' and where the 5' crosses the 4 ' line gives you your square......but its much easier with a ready made square.. the once you are happy with your centres set out from them checking all ways for stupid little cuts either dry lay or make a marking stick.. allways remember the six P,s...PROPER ,PREPERATION,PREVENTS, ****,POOR PERFORMANCE.:yes:
S.E Tiling
Wickes do a folding square and B&Q do a stanley one a bit dearer though.
I dry lay tiles in all directions first, then when I get started nail down a bit of dressed timber, folding square and an aluminium machined edge. Fix a row along the machined edge, then work away. Once I have finished that side, I take up the machined edge and tile from there. Weigh down the machined edge with spare tiles and bobs ya uncle!!!!!!!!
Reply to Straight row!!!!!!! in the British & UK Tiling Forum area at TilersForums.com
I just set new porcelain 8 x 8 tile in my rear entryway (3 ft x 3 ft area). I love the results...
Straight row!!!!!!!
    Votes: 9 5.6%
    Votes: 17 10.6%
    Votes: 11 6.8%
    Votes: 44 27.3%
    Votes: 21 13.0%
    Votes: 38 23.6%
    Votes: 4 2.5%
    Votes: 3 1.9%
    Votes: 22 13.7%
    Votes: 19 11.8%
    Votes: 17 10.6%
    Votes: 8 5.0%
    Votes: 5 3.1%
