Discuss Subject: EICR Findings - Advice on Coding Required Electrical Advice in the Electrical Advice area at TilersForums.com.
Subject: EICR Findings - Advice on Coding Required Discussion ThreadSubject: EICR Findings - Advice on Coding Required Electrical Advice
Hi everyone,
I recently completed a domestic EICR and came across something unusual. There’s a 10mm² twin and earth cable directly connected to the 100A cut-out fuse at the service head. The cable is concealed within the client’s wall and reappears next to the consumer unit, where it connects to a feeding cable that supplies the neighboring property.
After further investigation, I discovered that this cable is supplying power to the off-license shop next door and two flats above it.
Would you classify this as a C2? I’d appreciate your thoughts on this situation.
[ElectriciansForums.net] Subject: EICR Findings - Advice on Coding Required
Subject: EICR Findings - Advice on Coding Required for the original thread on Electricians Forums
Reply to Subject: EICR Findings - Advice on Coding Required Electrical Advice in the Electrical Advice area at TilersForums.com
Lou
Staff member
Admin
Staffordshire
Website
https://www.TilersForums.com
What member type are you?
Business Name
TilersForums.com
Electrical Advice
Tags
None
    Votes: 9 5.8%
    Votes: 15 9.6%
    Votes: 11 7.1%
    Votes: 46 29.5%
    Votes: 19 12.2%
    Votes: 37 23.7%
    Votes: 4 2.6%
    Votes: 21 13.5%
    Votes: 18 11.5%
    Votes: 17 10.9%
    Votes: 7 4.5%
    Votes: 3 1.9%
    Votes: 4 2.6%
