L
Lawrence147
Hi Guys
Haven't been here for a while but working hard , very busy and always learning, both out there and on here. As usual, I can only dream about emulating your high standards on jobs on here
Am currently doing a bathroom refurb for friends - am tiling a victorian tenement flat - a long and narrow bathroom which comprises a sink and bath in one area, leading to a toilet under a window in a separate area at the end.
The areas to be tiled are the sink splashback to the floor, the opposite shower area 2 mtrs x 1.6 mtrs and the toilet back board in addition to the floor. The rest is being papered and painted.
I have cement boards for screwing to the floorboards for 600 square porcelains, 305 x 305 Natural Stone field tiles (last boxes to be sealed tomorrow) powdered Weber addy and SBR for all areas and Mapei White addy for the 3 vertical mosaics I'm putting on the 3 wall areas. Shower area will also be tanked.
My problem is the substrate - the render behind the plaster around the bath is loose in several areas due to the age of the prop and the last time any improvement was done in this room. To give you an idea, tonight I removed 10mm quartered ceramic 'beading' from the wall side on the bath - I don't think that's a new idea!
I don't want to rip these areas out as the affected render is not, as far as I can see, over the whole wall, I've already papered so the mess would put me back days and this wall looks as if it's been rendered and plastered too many times so I think I would have to move the bath, frame and plumbing to keep it tight to the wall. I feel as if I'm opening a can of worms here.
In my research, I found a solution involving drilling holes around the affected areas and sinking PVA behind the plaster but know that's not a safe option here.
Can I overboard with 12mm P/B with glue and larger rawl plug fixings that will grip the brickwork behind ensuring a safer substrate for tiling? Obviously, I don't want my friends (or any cust for that matter) being knocked out or worse from a tile fixed to this failing substrate.
Can any of you pro's advise on this or any of my plans for this job that I've described above
Many thanks in advance.
Lawrence
Lawrence
