Discuss Superflex Widejoint + GT1. What sealer ? in the British & UK Tiling Forum area at TilersForums.com.
F
FussyGit
Difficult job, large chipboard floor area (over 120SqM) all done in Fastflex. Ceramic tiles in various sizes from 300 to 450mm. Will be grouted (5mm) with Widejoint in Limestone. The BAL man says Admix GT1 at almost 50 percent.
Customer is asking about sealer - they had a nightmare in the past with normal white floor grout. I know GT1 helps repel dirt - but not sure how much - would it be enough ? It is ground floor of a domestic house.
Thinking of something like Hagesan HG protector but area and time it would take to apply makes it expensive so want to be sure it is going to work and not cause problems - by say not bonding to the grout because of the GT1 in it ?
Any other suggestions to seal floor ? Or should advice be that it'll just need to be cleaned properly every so often ?
FG
DHTiling
There is a difference between sealing grout joints and sealing tiles themselves, and depending on the type of tile you're installing you should use one or the other.
Glazed ceramic tiles only need to have the grout sealed. Sealing tile grout gives your tile surface greater water and mildew resistance, and is indispensiable for keep ing grout from getting dirty. Unsealed grout will absorb dirt, grease and grime such that it becomes impossible to clean.
When you should you apply the sealer? For a new tile surface or re-grout, nearly all grout manufacturers advise that you wait at least 48 hours after grouting before applying sealers so the grout has time to finish setting. For maintanence of existing tilling, you should re-apply every year or two.
There are two main classifications of sealers: Membrane Forming, and Penetrating.
  • 1) Membrane Forming Sealers: These type sealers will resist water. They are mostly employed as grout colorants with added pigments to change the original color of the grout. Membrane sealers should only be used on unglazed tile because they will not adhere to glazed tiles. They generally stay on the grout's surface, forming a nonporous membrane with a glossy finish.
    In high moisture areas like a shower, water will find it's way to the tile/grout underlayment- using a membranous sealer makes it hard for the water to get back out and let the grout dry. This can be cause issues associated with prolonged water exposure, like rot, mold and mildew. So best to use this type sealer only with floors.
    2) Penetrating Sealers: Penetrating sealers soak into the microscopic voids of the grout. Typically made of Silicon or latex solids suspended in a water or mineral spirits base, after application, the base evaporates, leaving the solid material within the grout. The material fills pores and capillaries close to the grout surface and in so doing, reduces the absorption of potentially staining compounds.
    Non-pigmented penetrating sealers don't produce a gloss on the surface, but can slightly darken the grout's natural color. Use a good quality penetrating sealer like Aquamix for baths or showers. After the sealer dries, the grout looks normal until water is comes into contact with it, and then the water will actually "bead up", as if it your grout had wax on it.A Silicon, acrylic, or water-based grout sealer is applied to the joints. It's ok if you get some sealer on the tile surface providing the tile is glazed, but be sure you wipe it off before it dries, or it will be there for good. You need to remove any excess penetrating type sealer from the tile at once. It dries fairly quick, forming a haze on the tile that is about impossible to remove.For epoxy based grouts, sealing tile grout is not required, unless specifically stated in the manufacturers instructions that applying grout sealer is advised.............dave....
Reply to Superflex Widejoint + GT1. What sealer ? in the British & UK Tiling Forum area at TilersForums.com
Hi I am looking to purchase a textured tile called Jewel from topps tiles, they have small...
10K
Speedoman
Hi Lads, Anyone had any problems adding Bal GT1 Admix to Mapei grout ? Got a job next week...
6K
Tony Cooper
Hi guys, I'm in the process of creating a wetroom at home. So far, i've done the tanking in the...
6K
Hello all, I wanted to put up a little bit of info on LTP sealers to go with the post I put up...
12K
I
Here’s some advice on cleaning and caring for your new ceramic tile flooring: Sweeping Dirt...
Irfan
I
    Votes: 9 5.4%
    Votes: 17 10.2%
    Votes: 12 7.2%
    Votes: 47 28.3%
    Votes: 21 12.7%
    Votes: 39 23.5%
    Votes: 4 2.4%
    Votes: 4 2.4%
    Votes: 22 13.3%
    Votes: 19 11.4%
    Votes: 17 10.2%
    Votes: 8 4.8%
    Votes: 5 3.0%
